hi i have question how i can explode walls into lines in revit i need this method to use trick of creating complex ornamental shape save me time of offset and trim
how to explode walls into lines in revit
No such thing as "explode" for fundamental elements in Revit....except to export to dwg/dgn/dxf. Revit's perspective is a wall "exploded" isn't a wall and therefore "useless" as one. The export process will give you lines if lines are what you were really after.Last edited by Steve_Stafford; August 27, 2011, 03:54 AM.
Ahmed,
Put a yellow sticker note on your monitor saying: "I will never, ever explode a cad drawing in Revit" This will save you a whole lot of grief further down the track.
Cheers,Ian Kidston
http://allextensions.com.au
Originally posted by ahmed_hassan View Post... i need this method to use trick of creating complex ornamental shape save me time of offset and trim
Start Offset command, hover pointer over line chain, press Tab on the keyboard and then click the side that You want to offset.Regards,
Neboysha NOVKOVICH,
OOO NPP "TIS", Kharkov,
Autodesk Community Member.
Originally posted by ahmed_hassan View Posthi i have question how i can explode walls into lines in revit i need this method to use trick of creating complex ornamental shape save me time of offset and trim-Alex Cunningham
Originally posted by ahmed_hassan View Posthi i have question how i can explode walls into lines in revit i need this method to use trick of creating complex ornamental shape save me time of offset and trimDan
simply like this picture you can use pick line to create wall tool with thickness 0.05 so now i do not need to offset or trim because wall tool will do the task this is just as example what if i have complex ornamental i think the revit is quite missing some features never ever explode for example is one of missing feature to use or not recommended i do not like to work on line tools a lot i love working on massing and here by offset and trim remind me with old fashion autocad no matter i should listen to you advices because you are expert more than me and if i do not like that as all of you said maybe i shall back to any programme i love and wait for revit 2013 make magic change
Unfortunately when i export drawing to dwg, some hidden things are shown. For example i used few white lines . Does somebody know how to export without...June 2, 2011, 01:37 PM
Hello everyone,
I have recently started to use Revit at work with the intention that I would be more efficient. However, when I export the...October 6, 2015, 04:43 AM -
I am modelling unique signs that I do not have fonts for by converting images to .dwg and importing into a Revit family. Then I create an extrusion picking...
November 10, 2014, 03:51 PM -
The question of wall center lines has come up a few times both in here as in other locations on the web and there have been a few 'workarounds' offered,...April 22, 2014, 05:58 PM
Hi there. I need to export 2d views to dwg for my collaborators, and the gypsum interior partition walls need to look like this:
That horizontal...July 26, 2016, 07:03 PM
Monumetric Footer In-screen
