If added at the project level...you can assign a shared parameter to a category. All families in that category will have that parameter. Eliminates the need to open every single family and add the parameter.
The model we have is of an existing bridge (modelled from a point cloud - Looks awesome!!). As some of the elements had to be modelled in place and are objects not within the delivered toolset they have been modelled as 'Generic Models'. Others have been modelled as Columns etc. I'm assuming when you say Categories you mean these?
You will have to forgive me...Im a Revit Newbie. Could you provide a step by step please?
For anyone else who reads this with the same question I had...
1) In the Project, go to Manage> Project Parameters.
2) Click Add. This brings you to the normal(ish) dialogue box for shared parameters but with the addition of a Category selection pane.
3) Select the Shared Parameter/s you want to add. Make sure you have the correct settings (type/instance etc.) selected
4) Check the categories you want to add the SP to
5) Click Ok
:bb:
If you need any more help, check the following link out...
hi
What im fighting with is getting all the information from the Project Information button under Manage Tab. The reason is there is a lot of information...
I know with the Extensions you can convert familiy parameters to shared parameters but I would like to do this with project parameters. Does anyone know...
Are there any cases where it is a good idea to use a shared parameter you created instead of a built-in parameter that comes with the family category?...
So I have this fun problem where I built a bunch of families and created all my parameters in the desired parameter category groupings, but when I loaded...
