I'm asking here for a way to hide this orange rectangle, it's a void , I just want to see the opening only , I don't want that void mass , how can I do this ?
Thank you
use the Cut tool, select the solid then select the void. The void will disappear
It seems like every time I convert a normal extruded form to a void form in the properties menu; that the void does not create a void. The outline just...
Void extrusions in a family. Revit 2015. Why does it turn orange and not cut the geometry??? When I try to cut it manually, it tells me "cannot keep...
Hi everyone. Here is my issue. First, I was working in conceptual mass environment, not in In-Place. I first chose a horizontal reference plane, then...
The attached file has (2) voids in it. The only way I can select the 2nd void, is if I delete the 1st void. Curious why that is, and if there's a way...
