I've been charged with the task of incorporating the as-built points that our surveyor recorded in the field into our building model. He basically recorded the points into his survey equipment and exported a .txt file, a .csv file, and a .dxf file of the points.
I have added the Autodesk point layout plug-in. Basically what i'm wanting to do is import the "as built" field survey points into my model to check the difference in plan to as built dimensions on columns and so on. i have inserted my survey points but having to manually move them in place. is there an easier way to add points in place? a step by step process in properly importing survey data using the point layout plugin would be helpful to get the ball rolling.
Thank you,
Thank you,
