Does anyone have copper fitting families (and lookup tables)? I mostly need "Cross - Soldered - CU.rfa" or a bronze equivalent.
Copper Fittings
So, when I select certain fittings and draw a vertical pipe, the fitting disappears after I select Apply. You can see in the image, the pipe with the...
Channel: MEP - General
December 4, 2014, 04:05 AM -
Does anyone use Revit for Pressure Loss reports?
I am trying to get it to work correctly but keep running into problems:
- My fittings
July 17, 2013, 03:17 PM -
I created some connections families, but when I use some of them, they insert in the wrong side.Can someone help me?Look the images.
Channel: MEP - Family Creation
January 29, 2014, 12:05 PM -
Hello admin, would it be possible to create a sticky for problems with building MEP pipe fittings?
This is a question I have already answered lots...-
July 11, 2014, 12:09 PM -
Can someone please shed some light on an issue for me.
Working with Revit MEP, I am creating new pipe fittings and have come stuck on one...-
January 7, 2013, 03:24 AM -
