Question: Component with the same size over irregular Surface
    Hi people! I'm from Brazil! sorry anything in my english, ok?
    I have a question for you.
    I have a surface and I want cover this surface with a component, but I need a component with the SAME size OVER all surface.
    What can I do? I'm trying with Metric Generic Model Pattern Based, but the size of the component change according the surface.
    Do you have any idea how can I do this?
    I'm going to post a picture with the result until now, but I need a component with the same size!
    Thanks for listening
    1. build the panel as a generic model with the necessary parameters.
    2. load it into a generic model pattern based family
    3. host the generic model family on one of the points of the generic model pattern based family
    4. load it into a mass family. Patterns can also be created by using model line
    The following links can be usefull:
    buildz: Orthogonal on Placement: making a brick wall
    buildz: Conceptual Modeling Tips with Joe K
    buildz: Making Custom Patterns?
