I am doing the estimation of a project and I would like to know which method are you currently using for extracting QTO from the Revit model.
QTO Method
Originally posted by shyock View PostI am doing the estimation of a project and I would like to know which method are you currently using for extracting QTO from the Revit model.I'm retired, if you don't like it, go around!
The Quantity Take Off of all the elements to calculate the estimated cost the most difficult takeoff are the walls and finishes. I was trying to use Naviswork but I am having some troubles with finishes QTO.
I think Autodesk QTO does not exist now it is Naviswork.Last edited by shyock; April 20, 2017, 03:26 PM.
Originally posted by shyock View PostThe Quantity Take Off of all the elements to calculate the estimated cost the mos difficults takeoff are the walls and finishes. I was trying to use Naviswork but I am having some troubles with finishes QTO.
I think Autodesk QTO does not exist now it is Naviswork.I'm retired, if you don't like it, go around!
What you absolutely should not do is blindly trust a model for any QTO. If it wasn't modeled with that in mind, there's not just a good chance but a near certainty that the information won't be as correct as you might think it is/should be.
But, assuming the model is in good shape, I would use Revit Schedules to extract any and all (or nearly all I guess) of this.Greg McDowell Jr
about.me/GMcDowellJr
Hi all!
I am creating a set of families and types to be used as office partitions. I've created some panels (metal, glass, double-glass,...-
April 7, 2018, 03:48 PM -
Hello,
I have a question about the curtain wall. I'm working for a curtain wall supplier. Last time the customer would like to receive our...July 5, 2014, 03:30 PM -
Hi guys! I want to create a family for metal formwork. Im thinking about use curtain walls or component but im not sure. I need something like the next...
Channel: Structure - Family Creation
February 5, 2015, 03:02 AM -
I am currently working on building some custom curtain walls for our office.
I started by basing it on the OOTB Revit curtain walls....-
January 23, 2020, 05:42 PM -
1. I have a series of the same length curtain walls to be embedded in a regular wall. The curtain wall's type property is set to automatically embed....April 26, 2012, 01:46 AM
