Moment endplate connection
    Hi Folks, very new to Revit, so please bare with me.
    I am trying to connect moment endplate on a 150x75 PFC to a plate welded to the flange of a 254x146 UB
    see image attached.
    Revit 2018 platform T "how do I turn of the "|" part and just keep the "-" endplate
    All help will be greatfully received
    The image is 2 manually added plate, there has to be an easier way
    Hi and welcome,
    Manually added plates are fine, in reality, but they are a bit of extra messing around to place.
    I'm not actually sure which part you are wanting to turn off in your question, do you mean hide the beams?
    If you don't want to do manually placed plates, try the "assemblies" tool Under the "structure" tab.
    You will need to set the rules for the connection, (ie moment etc.) and some other rules but they are straight forward and revit will place automatically for you the connection, and modify it automatically if the rules happen to change also.
    Having said that, I am not 100% sure it will do a flange plate in this manner for you but Worth checking out at least, and assemblies will save you time in general.
      end plate
      Originally posted by Karalon10 View Post
      Hi and welcome,
      I got it sorted with revit 2018 but thankyou for replying ;-)
