Issue Parametric door family
    I am busy with creating a door family in Revit 2016. The door has an option to turn or off the "neut" which is a skirting block on the frame. When you choose the option to turn off the skirting block, the first visible frame with the skirting block goes invisible and the second frame becomes visible without a skirting block. The problem I have it that I somehow cannot allign the top frame of the second frame to the wall. Does anyone understand what I did wrong with the frame that appears when "neut" is off? Open the family in a project to test it out!
    Thanks in advance,
    Selim
    Can you post some screen shots and your family. You will get better feedback that way ;-)
    I used to be high on life, until I realised it was cut with Morons.
    Combating ignorance daily through learning.
