.dwg export: my layermodifiers are not working?
  • mariusvanwyk
    Go to tab "Farben" and check "true color(RGB values). It will then export your view with selected layers but with your Revit RGB colour settings for categories and filter override settings. As said set in layers " BY LAYER and BYENTITY. Any way if client LAYER names are important great but your view setups will trump the colour war.. let them worry about that.
    Sent from my HUAWEI VNS-L31 using Tapatalk
  • andreasdraxl
    I almost achived it:
    You have to change BYLAYER into BYENTITY so you get the layer from the modifieres... but it is still not correct
    fittings, tubes, ... have different colors in the same system
  • andreasdraxl
    started a topic .dwg export: my layermodifiers are not working?
    Hello,
    I am new in the field of mep.
    for A deadline i have to export my floorplans in .dwg
    So the client has a layerlist, particulary are the different MEP Systems are important. Each of them has his own layer!
    The system are well done in revit (colour, lines, patterns,...)
    But when I do my export every system is just one color!
    What do I wrong?
    I am glad about every advice!
    Kind Regards
    Andrew
