Left handside panel is missing!!
Originally posted by MPwuzhere View PostDave knows this because he drinks a lot of wine.... :hide:
to the OP, in case you didn't know you can combine your Project Browser and Properties palette like this
or, you can have them one on top of the other like this
personally I keep mine separate on a 2nd monitor but if I was using a single monitor I'd definitely do the combo switch back and forth optionLast edited by Dave Jones; April 16, 2017, 11:52 PM.I'm retired, if you don't like it, go around!
Have you ever used Reconcile Hosting? When you click the appropriate button in the Ribbon, a new UI panel appears (see image below). You can also assign...
Channel: Blog Feeds
September 23, 2013, 02:15 AM -
Hi. So I have a panel all set up, but now I want to change the "Supply From" field found in panel's properties and in the panel schedule. I...
Channel: MEP - General
March 31, 2015, 08:46 PM -
The ribbon User Interface will let us turn off the ribbon's panel titles. I've never bothered to do this and today I was asked why a user's ribbon was...
Channel: Blog Feeds
August 15, 2014, 11:15 PM -
In a large design with many electrical circuits and with a panel located on the other side of the building, is there a way to find a panel's location...
March 17, 2014, 10:42 PM -
Hello,
I am using Revit 2013 and out of the blue every time I use the build command - for instance when I draw a floor, the draw panel is...February 12, 2015, 07:13 AM
