Read only Parameter error from Element.SetParameterByName node?
    see this. Why would the built in Revit Sheet Number parameter throw a read only error?
    What element are you feeding the node?
    Greg McDowell Jr
    about.me/GMcDowellJr
      A sheet list
        At least in earlier versions of Dynamo, not all parameters could be obtained this way. You has to use Built-In parameters. Still, I'd surprised this was one that needed it. There aren't non-editable sheets in the list, like from a linked model, by chance?
        Greg McDowell Jr
          nope, in project sheets using the OOTB Revit Sheet Number instance parameter. Add Sheet Numbers.dyn is attached. The idea is to connect the String.Insert wire in the Add Temp Suffix group to the Element.SetParameterByName node to add a "z" suffix to all sheets including the sheets being added to get around the Revit duplicated sheet error. Then connect the wire from the String.Insert wire from the Add Sheet Prefix group to the Element.SetParameterByName node to delete the suffix. The initial wire connection brings the error on Run
          btw, credit for this graph to Michael KilKelly at ArchSmarter in a YouTube tut
            There is a known bug that is looking at getting addresses in a future release of Dynamo. Basically, there is a conflict issue between named parameters and 'nicknamed' parameters.
            The best work-around at present is to use the Built-In Parameters in lieu of the nicknames.
            Sol Amour
              isn't the instance parameter "Sheet Number" an OOTB built in parameter? The project that I'm running this graph on has no project parameters so in theory only built in parameters would be available. Unless I'm unclear on the concept which could certainly be the case as I'm only a few days into the Dynamo learning process.
              I'm attaching a small project file with the sheets created. I have sheets A100 thru A180 and A200 thru A205. I'm trying to add 5 sheets into the list in the A100 series and they are included in the sheet list with an "A" suffix to get them in the correct order where I would like them added.
              I am using Dynamo 1.2.1 in Revit 2015
              Edit: just for grins I installed Dynamo 1.3 and ran the graph in R2017.2 and it works perfectly. Some issue with either Dynamo 1.2.1 or R2015 or both
                I tried to find the Github link but failed... not my day I guess
                Effectively, there is multiple parameters in Revit called the same thing. So it get's confused and tries to set the 'Read Only' data rather than the other. It's because the Revit API is 'fun'. It's definitely random in it's uptake - and generally you don't see the issue.
                Sol Amour
                  Yes, in 1.3 they improved the handling of parameter names. What used to require a BUILT-IN can now be done with the "nicknamed" versions.
                  Greg McDowell Jr
                    thanks amoursol! lots to learn about the idiosyncracys of Dynamo
                    well, that sorta sucks since I have 3 projects going in R2105. Oh well, the graph will be useful in the future. Thanks Greg!
