Seeing Objects Through Walls
    I am seeing objects (walls, counters, model masses, components) through my walls in Revit. I have tried turning off the view template and turning the visual style from hidden line to wire frame and back to hidden line but it is staying the same. Please let me know if there is anything I can do! I have attached a screen shot and circled some stuff that I am not wanting to see.
    Check cut plane, your counter is above the default cut level so this may be a reason.
    Revit add-ins: Purger (delete UNUSED and selected line patterns & line styles, find & delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager (with bunch of other features) at Revit Exchange Apps, View Filter Manager ML
      Pretty sure it's the elevation view that's the issue? Do the front edges of the shelves align with the outer face of the desk? If so, pull them back so they don't intersect. Then start checking other stuff like visibilty /graphics overrides
        Are some of thoese elements imported objects? They can do funny things to views. Does creating a new section have the same issue (views can be corrupted)?
        Julie Kidder
        Architect + BIM Director
