I started a similar thread on another forum and later found the subject covered in a post on Autodesk Knowledge Network. In a nutshell, the concept is to use Revit's improving presentation capabilities AND avoid having to create a bunch of redundant materials that display surface and sections correctly. One is currently able to assign a material to an object (steel for a steel beam for example) that cuts as expected with the proper hatch pattern. One can also apply a surface finish using the paint tool. This way you can apply the same color to different objects and not worry about how it cuts in section, thereby avoiding the redundancy of having blue paint for wood and blue paint for steel (for example). This is all in THEORY. In practice, Revit uses the painted surface material's cut pattern for cutting the object!
The solution from Auto desk is to try a different approach! I guess switching to ArchiCAD could be that different approach...but an unlikely one of course. A person by the name of Alex summed it up nicely on Autodesk Knowledge Network(hopefully it is ok for me to copy/paste from their post):
"BAH... sounds like another half-baked Revit feature. If your view cuts through more than one painted surface on a model element, then it thinks that element is the painted material. Revit really needs a way to manage and differentiate finishes from materials. I see posts about this dating back 6 or more years. ArchiCAD did this 3-4 years ago by implementing "Building Materials" and "Surfaces", and it's beautiful.
I hope Revit gets on the board with the idea that BIM isn't just about model information anymore, and requires just as much intelligence in visualization. Right now we have to manage the model & visualization relationship with TONS of redundant materials that bog the environment down, and are a headache to update.
Thanks for your help Toan! I'm open to ideas on other approaches!
Kind Regards,
alex"
Here are links, the first one from 2010 that introduces the concept (almost 7 years ago!), one from 2011, and then the link from Autodesk Knowledge Network.
Paint face in component?
What Revit Wants: How to assign a parameter to a painted surface in a family
https://knowledge.autodesk.com/suppo...p/6817716.html
Autodesk...please fix. Thank you
Kind Regards,
alex"
