I have started a new project by linking in a dwg. There will be several building on this site. Since the dwg came in at true north, I set up project north in order to draw the building straight and square. When I did this, the crop region also rotated along with everything else (elevation bubbles etc.). Now I can draw the building correctly, but the crop region and elevations are at an angle. I can't figure out what I am doing wrong. Any help is welcome.
Project North Rotation Problem
Link your dwg into a true north view (typically a site plan). If your elevation markers are already placed before you rotate project north then they will rotate as well, Revit is simply maintaining what your existing elevation direction. You can rotate your elevations back or place new ones.There are no stupid questions, only stupid people
I have a linked dwg (site plan) that came in at true north. When I try to rotate to project north the crop region rotates with it. I haven't had this...March 9, 2017, 12:52 PM
I've got a project that has a rectangular property line which is more or less the same proportion as a D-size sheet, but is not aligned to either project...December 22, 2010, 06:25 PM
Ive read up on the subject and played about with my current project but theres still one or two things i'm a bit lost with and was hoping someone may...December 16, 2014, 08:12 AM
I moved the true north at the beginning of my project to make modeling and understanding of the project easier (89°)
My problem is that...December 4, 2020, 11:41 AM -
Say you have a building that is long and skinny along a N/S axis and you want the plans to fit on the sheet horizontally (i.e. rotated 90 degrees) Do...December 5, 2014, 07:27 PM
Monumetric Footer In-screen
