Hello guys,
I am currently creating Tag Families for our company's Revit template. The goal is to make them look as close as possible (visually) to our standard in CAD.
The issue I am having is with the shoulder line for my Mechanical Equipment Tags or Duct Tags etc. I was able to create a tag which connects the leader line with the shoulder line (the shoulder line is created inside the family).
The problem starts when the text itself is longer. The line should approximately follow the length of the text. I was able to avoid the problem by creating a few lines with different lengths in the family and adding Graphic Yes/No parameters to them.
The question is: Is there a smarter solution to this? Is it possible to somehow connect the line with a parameter to make it automatically longer as the text gets longer too?
