Ramp - modified floor
    Hey guys,
    I am a bit frustrated with this one.
    I am trying to plan a road outside the project and a ramp to go through the plot until the parking area.
    Both have sloped areas. I ve used a floor and modiefied the point to create the slopes i neaded. That killed me!!!!!
    After as you can see on the section i tryied to built wall and foundation on both site of the ramp...
    The only thing that worked was generic models with swept blends!
    But as you can see i had to do it part pro part and the connections of the generil walls are terrible!
    Is there any better way to do this? am i so wrong on it?
    Thanks!
    The Swept Blend method has worked for me for a stair railing. Have not tried it in siteworks.
    Before you start the wall, create a Profile family that defines the profile of the wall to sweep. (A rectangle the width and height of your retaining wall.)
    Create and In‐Place family of Wall category; create a Swept Blend; define the (flat, horizontal) path of the stair/footpath/ramp in a Plan view; choose your profile as the start and end profiles; (and this is the important bit) set the Vertical Offset for each profile to specify the heights for your sweep's start and finish.
    Note that alternatively you could define a different profile for the start and finish of the sweep.
    Hope this helps.
      Originally posted by sotekt View Post
      Hey guys,
      Thanks!
      This is why it is suggested to use roofs instead of floors...
        I still dont get it!
        In the way that my road/ ramp is.. how is the besto way to just make the ramp first of all...? as a family? as a sloped floor or roof?
        Any links that i could see any videos?
        Thanks
          Thanks
          I already said...use a roof...see attached.
            Okey i will use a roof... but is there any way that i a floor plan these lines wont appear?
            thanks again
              yes, in your VG settings scroll down to floors and open out the + sign and uncheck "interior edges"
