water falls
    water falls
    can anyone suggest how can i put water on the waterfalls rocks thanks
    Yes, use a swept blend shape with a water material that looks like a water in section, basically wavey shape as tight or rough as you want. Then use a revolve or sweep for the ripples where it hits the water. Yes this image is 100% revit.waterfalls.jpg
      Originally posted by sdbrownaia View Post
      Yes, use a swept blend shape with a water material that looks like a water in section, basically wavey shape as tight or rough as you want. Then use a revolve or sweep for the ripples where it hits the water. Yes this image is 100% revit.[ATTACH=CONFIG]29926[/ATTACH]
      That looks great Scott.
      You could also create sweeping forms in the massing environment.
        For a rougher water fall look I've taken imagery from a waterfall, messed with it in PS so its seamless then used it as a material.
          Water fountain
          Do you mind sending me the water fountain? I'm not succeeding in making the sweep blend.
          thanks
            wall fountain
            Here is the family, its quite old but you'll see how I did it.
