I'm sure it is something simple but I've banged my head against the table for to long on this one... See the attached family. I cannot figure out why when I insert this family into the project environment that the masking region isn't masking out the modeled geometry. Thank you all in advance!
Masking Region not masking
The masking region is placed at the highest point of the geometry of the family
As the highest point of your geometry was what to mask,did not work
That only needs a little push
by the way
Why use a mask if the rest is modeled?"-Bueno, pues ahora que los dos nos hemos visto el uno al otro -repuso el
unicornio-si tu crees en mi, yo creeré en tí, ¿trato hecho?"
Lewis Carroll
Hello,
I created a casework family with a masking region set to Foreground. It masks when it is in front of other families but not when I...-
October 9, 2014, 01:02 PM -
I have a chair family and table family. Each has a masking region that is being used to simplify the plan geometry. When the two are place in a project,...
August 22, 2019, 06:22 PM -
Is there a way to set the masking region depth? I need to see the components 4 feet down, but hide the regions directly below the mask.
Thank y...March 10, 2015, 05:46 PM -
Hello,
Follow steps
Open revit project file
Select any lighting fixture family, go to family editor & create masking region...-
Channel: MEP - General
October 22, 2013, 11:08 AM -
Here’s one that really got me in a quandary; hope one of you Revit brainiacs can help me figure it out.
Why is a Masking Region that...January 26, 2016, 04:48 PM
