Please share any sucess or horror stories you may have about eTABS.
eTABS -> Revit
Hi Alex:
this is a example application of csixrevit 2011:
http://www.4shared.com/get/yc8-stSP/ejemplo.html
regardsLast edited by CLAUDIO_DPS; August 31, 2011, 02:37 PM.
I'm using Revit 2014, when i try to use the Rebar this message appear,
(hooks will be included in Rebar Shape definitions. this option...-
May 17, 2013, 05:23 PM -
I was tinkering around with the rebar placement and got it working (woo!) but the rebar shows up in all my sections, even when it should be covered by...November 26, 2013, 08:57 PM
Dear Revit guru
i'm use Revit structure r14 and i load us metric rebar family. When i select rebar for change type of diameter. I cant find R TYPE...-
June 4, 2013, 07:34 AM -
Is anyone very familiar with the concrete reinforcement Revit extension?
December 23, 2010, 02:29 PM -
I am trying to place a set of rebars between stirrups in a column. However, the edge of the rebar does not snap correctly to the stirrup...-
July 31, 2017, 08:32 AM -
