Shared parameters between categories
    Hi All,
    I have a questions regarding the „reading“ of parameters between categories.
    For instance, inside my Air Terminal I have a shared parameter (Let's call it Air Terminal) that is used to enter supply temperature to the room.
    Is it possible to use that shared parameter (Air Terminal) inside Space schedule, or other way around?
    To be more precise, I would like to enter supply temperature inside Space schedule and when I position Air terminal inside that space that Revit recognizes those are same parameters and that automatically use that value, or other way around, to enter temperature inside Air Terminal and that Space schedule recognizes that is the same value (something like how Revit calculates actual airflow based on entered air flow inside air terminals).
    Best regards, Branimir
  • Shared Parameters for Air Flow
    Hi All,
    as I was googling I found out that the usual way to define fresh air in AHU is like supply air, right? Now I am interested...
    February 12, 2016, 02:41 PM
  • compressed air setting 6bar
    doeas anyone have the parameters for custom compressed air setting that must be filled in (schedule of mechanical setting ) dynamic viscocity and density...
    August 7, 2018, 01:23 PM
  • revit mep problem
    I have a problem, and I wonder is it possible to solve it.
    I was created a space, and I created a zone, and in zone i define a Air per change ,...
    July 27, 2012, 10:24 PM
  • Outside Air System
    There is a bit of controversy here as to what an Outside Air system is to be based on. This is the air that goes from a louver via plenum/duct to the...
    August 26, 2014, 06:16 PM
  • Duct Systems
    I'm curious as to the proper way to do this.
    System description:
    Outside air through ERVs to bring it up to a minimum temperature...
    January 9, 2017, 06:39 PM
