Hey guys,
Not sure if this would be in the correct forum section but anyway, I'm quite new to Revit, I know some of the basic commands etc but basically I am wanting to model a shaft, and when I say shaft I mean as in not a "lift shaft" but more of a shaft in the ground. I'm not 100% sure on how I would go about doing this but anyway, here's a few bits which might help you assist me:
A few bits about the shaft:
I haven't yet figured out the best way to model this. I think one of my hardest obstacles may be making a 3D model of say one of the precast rings or the jacking collar. But would love to know how you guys would go about doing something like this!
Thanks,
Jake
- 3m Internal Diameter
- Precast concrete rings 125mm Thick 2100 I.D.
- Shaft has Jacking Collar 1200x1200mm.
- Structural Slab 6m below surface of shaft 500mm thick
- Base plug below structural slab.
Thanks,
Jake
