Sheet Renumbering
    Sheet Renumbering
    Dumb question on renumbering sheets: Usually when I need to renumber sheets it is because I have to add a sheet which throws off my sequencing. I can export sheets and renumber in excel with no problems but I hit an issue when I bring things back into Revit since the sheet numbers technically already exist. Is there a way around this that I'm just missing other than swapping letters around - i.e. A101 to B101 to A102?
    chad
    Depends how you are doing the renumbering from excel: you have to use a tool that let's you specify the processing order, and can work from the top down. I don't recall if yoy can do that with Spreadsheet a link or not. But I imagine you can if you resort the lists a certain way?
      You could do it with excel if you add an extra step. First import/change all your sheet numbers to something else (Like add a letter to the end of the existing numbers, still unique), then import the actual numbers you want.
      Personally I made a simple 'Find and replace' tool in dynamo for both sheet and view names. Extremely useful when you want to adjust part of the name for all sheets.
        Joseph's right, you simply need to add into your script an interim step that renames them to something arbitrary first.
        Exiting Names -> Arbitrary (So no conflict) -> New names (Utilising some existing names).
        You can use the Clockwork node Passthrough to make sure that your Dynamo sequencing executes in the correct order.
        Sol Amour
          Thanks! :beer:
          Is that something you can share? I'm good with just a screenshot - helps me figure things out on my end if I actually have to build it
          I'll take a look at it and see what I can muddle together.
          chad
            Something like this
              Cool! One quick question: Is the Change View Name node a boolean that you renamed?
              chad
                yep. I just gave then names to show what they do.
                Probably better to rename them "Boolean - do stuff" to avoid confusion.
