I'm working on a project at a new company that is large with alot of fire/smoke dampers and they want the level of the parameters in a schedule this does not appear to easily done. Am i missing something
duct accesories level parameter
No, they dont report level, or room/space for some stupid reason...
For ducts I understand why this is as they can pass through multiple rooms or levels, but this should be made available to duct and pipe accessories.
One solution is to use Dynamo to check what room/space they are in, or check the z coordinate against level elevations, and write that into a parameter.
Or, you could nest a small family from a category that does show level (Mech Equip) inside the duct accessory, link some params to show what the host is, and schedule those. Ive discussed this before here: https://www.revitforum.org/mep-gener...ermostats.html"One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
Multi Category schedule would work, but may require an additional Shared Parameter.
-TZTannar Z. Frampton ™
Frampton & Associates, Inc.
Ah yes, that does work.. but then you dont have access to any of the System parameters.
It amazes me how awkward and inconsistent access to data is in revit, considering it is just an sql database underneath."One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
If you examine the properties of a duct you'll see a parameter called "Reference Level". Do the same for a Duct Fitting and you get a parameter...
Channel: Blog Feeds
March 6, 2012, 04:15 PM -
My question is one regarding approach, or procedure, more than a direct Revit function with Duct.
Lets say you have a four story building...-
Channel: MEP - General
June 25, 2013, 07:09 PM -
Can Anyone help please, being new to revit i am finding it frustrating trying to create ductwork routes within my building,
has anyone got any good...-
February 19, 2015, 03:55 PM -
Is there a way to have a Multi-Category schedule with System Name? This parameter is not available by default so I'm wondering how I can harness this...
January 15, 2015, 11:36 PM -
How have you represented ductwork that's below the floor that it is serving? Ideally I'd like to be able to filer out what is below the floor but isn't...
July 11, 2019, 10:49 PM -
