Course View Fitting Partially Disappearing
    Anyone that can help me, it would be greatly appreciated - I have an issue with the outer elbows of some of my fittings disappearing. it is not a cut plane issue, because - as you can see - the top elbow fitting is a complete arch The fitting at the bottom is a sloped 45 pipe to a vertical. I continue to have the issue that the outer edge of the fitting cuts off. if I click on the elbow, it shows up, but when I scroll off of it, it disappears. Please refer to the image below. It may be an issue with the fact it is a 45 degree fitting, but I still need it to shown up correctly in plan view. If you know how to fix this view issue, it would be so helpful! Thank you!
    What happens when you print to PDF? Does it show differently? Sometimes MEP objects can seem to have problems visually but when you print it's actually just fine.
    Also, fittings tend to do weird things when they're slightly off kilter. For instance, sloped piping is common with Storm Drains and sometimes designers can forget to turn off slope when you change elevations to create a straight riser. This causes a subtle slope in the riser... where the fitting is like 89.9993° instead of a straight on 90° fitting, which causes the fitting not to be oriented to the view in a way where Revit can accurately display the fitting.
    And, sometimes, it's just the way it is. Single line piping fittings is always an uphill battle in Revit, unfortunately, but understandably due to the nature of a schematic version of 3D piping.
    -TZ
    Tannar Z. Frampton ™
    Frampton & Associates, Inc.
    • Wye Connection off sloped main pipe
      I'm on the architectural side of things playing with RME so i'm not really too familiar with this (although have read the shortcomings of sloping pipe):...
      March 12, 2011, 07:18 PM
    • Pex Piping
      We use alot of pex piping on our projects and I need to come up with a way of showing it better. Read somewhere about using the conduit fittings so you...
      December 31, 2014, 01:04 PM
    • Disappearing Fittings
      So, when I select certain fittings and draw a vertical pipe, the fitting disappears after I select Apply. You can see in the image, the pipe with the...
      December 4, 2014, 03:05 AM
    • Socket Weld Fitting
      I cannot find a single socket weld fitting anywhere
      anyone have any luck with a manufacturer that has a decent socket weld fitting to us...
      October 16, 2015, 04:41 PM
    • Duct System, fittings and settings
      Hello everyone,
      I'm working on a HVAC coordination project and there are a few ongoing issues with my fittings which I can't seem to solve....
      February 28, 2018, 04:53 PM
