Greetings,
I am having an odd thing happen with my rebars in my project. I have a concrete structure that is somewhat unusually shaped with rebar added. The thing that is odd is that when I cut a section, the rebar that is cut by the section shows up as it should, but also any rebar that is not cut by the section shows up as well. Does rebar default to displaying un-obscured? I have a section that has two walls cut by my section and a wall that is far-off in the section view not cut by the section line, but the rebar in that far-off wall is displaying. I know I can select the rebar and adjust the visibility settings for it not to display in that specific section view, but now I have to go back and do that for all the other sections I have already cut. is there an universal way to adjust the visibility settings?
I tried selecting all rebars in the project and changing the visibility settings so that nothing showed un-obscured, but then rebar that I did not want to disappear was now hidden. Any suggestions are welcomed. Thank you for reading.
