Solid Fill Regions - Set to 80% transparency - Still Printing Solid
    :banghead:I have used solid fill regions w/ Transparencies before.... (I was able to place a solid black fill over an image I wanted to fade) and it worked great!
    I am trying to do it now and the color shows up solid... I have looked for a way to fix this but cannot find one.... anybody out there got a quick fix for this one? I am most likely just missing a setting somewhere.....
    Thanks!!
    Regards,
    Emmett Cruey
    ConnectedBIM.Design
    925-695-6000
    okay found my answer!!!!
    somebody switched the view to wireframe... It has to be set to hidden line to plot properly!
    Regards,
    Emmett Cruey
    ConnectedBIM.Design
    925-695-6000
      Thank you.
        Isn't this forum marvelous
        Just after reading this thread I had exactly this problem - and the view was indeed in wireframe - switch to Hidden Line and transparent filled region plots perfectly to pdf.
        :beer:
        William Sutherland rias riba
        WS Architecture Ltd
          So the question now is: In wireframe, why does transparency not work?
          Answered my own question: Unfortunately its a known bug:
          https://knowledge.autodesk.com/suppo...-in-Revit.html
          Alex Page
          RevitWorks Ltd
            thank you. wireframe was the issue.
              also raster vs vector printing will make a difference depending on the hatch pattern, usually modelled object with solid fill will only work properly using raster print option...
              You might find (although I am not sure it will work) that if you set raster print and leave it on wireframe, it works as it should....not 100% sure on that one, worth a test.
