I hv trying to find Add-Ins tool in my RST(2011) prog but I fail to see it. But to my fellow computer who used RST(2012) had it, but extension manage does not appear. So pls I need your help how can I go about so tha I can see these tools.
Add-Ins
Originally posted by jamila.kibugila View PostI hv trying to find Add-Ins tool in my RST(2011) prog but I fail to see it. But to my fellow computer who used RST(2012) had it, but extension manage does not appear. So pls I need your help how can I go about so tha I can see these tools.
For both versions, Extensions are to be downloaded from the Subscription Center.
Hope it helps.
Lucian.Revit Architecture 2013 Certified Professional
Add-Ins
Sorry I still hv problem in RST (2011) to find add-ins tool in the menu bar, I'm using win XP. When I'm going to C:\ what is present in my computer is C:\ProgramData\Autodesk\RST 2012\(Family Temperate, Library, Temperate) instead of C:\ProgrmData\Autodesk\Revit\Addins\2011
and all folders after RST 2012 are empty.
Originally posted by Yan Naing Bo View PostHow can i get the Add-Ins ?
Could somebody share to me?
Originally posted by Munkholm View PostIn 2011 the add-ins should be placed in: C:\ProgramData\Autodesk\Revit\Addins\2011
In 2012 it´s been changed to: C:\Users\%username%\AppData\Roaming\Autodesk\REVIT \Addins\2012
Above paths are for Vista/Win7 :beer:
I can't get the Addins tab to show up in Revit 2012? Do you know what I'm doing wrong? I have added the hatch22 addin folder, RFO_RibbonAddins folder. But the addins tab won't show? Is there somthing I'm missing? I have tried to put them both in these directories:
C:\Users\*user*\AppData\Roaming\Autodesk\Revit\Add ins\2012
C:\ProgramData\Autodesk\Revit\Addins\2012
Thanks,
Lorne
How can I get Add-Ins Bar that is micng in ma prog RST (2011) and extension manage that is micng in RST(2012)
Channel: Structure - Family Creation
August 23, 2011, 09:28 AM -
I'm looking for some help with Revit connecting to Internet.
My company as a proxy to link the intranet to the internet....-
Channel: Third party Add-Ins, API and R&D
November 15, 2011, 11:53 AM -
hi, how to install revit addins silently without using the admin password.
Thanks.-
May 25, 2018, 07:49 AM -
I had this add on for RAC 2011. Is there one for RAC 2012? If there is I can't find it on the Subscription site. Or, maybe the 2011 version will work...May 27, 2011, 11:12 PM
This is maybe a question for the Factory guy's.
Why can you add most add-ins to the QAT but they don't stick, next time you open up Revit they...April 21, 2011, 12:15 AM
