Making a 360 degrees stair
    Hi everybody,
    I’m trying to make a circular stair but apparently it’s impossible to make it a 360 degrees circle.
    I’d like to make a stair in which you get in a in order to arrive to the other level you have to do a perfect circle. Is this possible? Any youtube video that can help me with it
    Here’s an image of my problem:
    You can get a 360 deg (or more) stair. You may need to do some math (riser heights, tread depths, and floor to floor) to get it to work out to be EXACTLY a circle.
    Jeff Hanson
    Sr. Subject Matter Expert
