Line weight
    Line weight
    Hi, I'm sure that you have seen other posts on this and I have been going through the ones I could find but nothing is helping. I am trying to set the line weight of my equipment. I have a few parts that are ending up as black blobs even though I have the line weight for that category set to 1. The parts are designated as mechanical equipment and they are parts that I got from the company website and I had to import them into revit. Any help would be great.
    Micah
    Update on this. If I just import the .SAT file it has thin lines but then I don't have a way to connect it to my system. Importing it into a family and then adding pipe connection points to it is when it comes in with thick lines and looks like the blob.
    [COLOR=rgba(0, 0, 0, 0.701961)]Second update I was able to get one of my parts to come in as I want by exploding it in the family and then adding my pipe connections. I tried this on the other part and 90% of it disappears when I explode the part.[/COLOR]
    [/COLOR]
    [COLOR=rgba(0, 0, 0, 0.54902)][/COLOR]
      I figured out how to change the line weight on the other items that i was having trouble with.
      Loading...
