Please tell me what is this and how to delete it!!!!
Structural plan view HELP!!!!!
It's a view crop...it lets you trim out excess of a plan or section cut, but keeping the dimensionability.
You can either turn off crop regions...or just don't click the little wavy S... But they come in handy when working on tall buildings with lots of wall that doesn't need to be detailed but needs to fit on a sheet.Michael "MP" Patrick (Deceased - R.I.P)
Is there any way to change the view type of a floor plan to a structural plan? I know I can create them using the plan view tool. But, if I already...August 27, 2012, 06:00 PM
Hi everyone!
I'm trying to do an orient view in 3D to a structural plan (view direction up) but only the foundations plan (view direction...-
March 9, 2012, 03:24 PM -
Hi, i'm using Revit Architecture 2013 and I found that I can't make a new structural plan since it's missing from where it should be, under View >...September 9, 2013, 05:51 AM
I'm trying to break a plan view into two sections to show only the relevant portions of a building on a sheet. I select the crop region, see and select...January 20, 2012, 04:52 AM
I have 3 sheets, sheet 1 has plan view 1, sheet 2 has a duplicate of plan view 1 for means of the example we will call it "plan view 2", sheet...February 3, 2012, 01:09 AM
