Hey there.
I was trying to create a family with a model text that have both labels to control its position: in X-axis and in Y-axis.
But it tells me constraints are not satisfied:
I need that because I'm making a family of signs, but unfortunately when I change the size of it, I'm not able to locate the model text where I need it to be. The first image shows the model text aligned with the pictograms (icons). The second image shows a different size of sign, so the model text is not in the correct vertical position anymore (not aligned with icons):
I could only add the label to control the horizontal position (instance parameter) OR the vertical position... Not both at the same time
Any ideas?
Thank you.
Any ideas?
Thank you.
