Consultant Doesn't Use Filters
    My Mechanical Consultant doesn't use filters. What's up with that? I can't think of one advantage. Anyone care to chime in?
    I am recreating my filters to recolor his systems according to system abbreviation because his systems are named Chilled Water Supply, Chilled Water Return, etc. Normally I create filters for System Type which I name CHWS CHWS, etc. But this consultant doesn't do it that way. Not a biggie but the first issue above (no filters) was a little shocking.
    Please share your thoughts.
    He doesn't need filters to apply color if he is assigning color via Piping System Type properties. A filter is desirable/recommended to control visibility...and certainly not via a workset.
    John Karben | IMEG Corp.
      I don't really think it's an issue and have never had a problem with it, but I've heard some arguments that filters can add extra regen time to the views. I think the benefits far outweigh any downsides.
        Here's his pipe properties. Wondered if you could comment on how the systems are getting colored?
          System Graphic Overrides accessible from the systems type properties.
          Thomas N Fuller II
          LinkedIn
            Originally posted by chris.macko View Post
            ...but I've heard some arguments that filters can add extra regen time to the views.
            Because of the large number of different systems that need to be distinguished from each other, consistently in all views, applying overrides per system is the easiest, fastest and most globally consistent method there is. Given the large number of filters that would be required to achieve the same thing, and the fact that if you want to create a new system type you would have to go through every single view template and set up a new filter, applying a Material via the System Properties is extremely efficient.
            It does also regen/render faster, because there is no logical test that needs to be checked for each element in the view for every filter, the system material is just a property of the elements. The difference is particularly noticeable when printing (To PDF at High quality in colour takes less than half the time with system materials compared to filters).
            There are smarter ways to reduce the number of filters required, like using reverse (IS NOT..) filters to hide everything you don't want, if you have a good hierarchical way of grouping types of systems by abbreviation.
            Ive only encountered a couple of times when architects have had problems with the system colours. I would be interested to know why using system materials is an issue and if there is a way to make it workable for other disciplines, because it really is a useful method for MEP views.
              Project Browser > Families > Piping Systems > Double click or Right-click > Type Properties
Name:	Piping Systems Type Properties.PNG
                That is very similar to the explanation I was getting at the time, and since I don't work in MEP and don't really have a need to show the systems, I can't argue with that logic at all. If there's a built-in way to accomplish something in less steps than filters than I'm all for that. I don't see how that would preclude them from using filters for anything else though. Using systems to color and sort things only addresses one graphic requirement. Like you said, reduce the number, don't eliminate them altogether.
                  Making the switch to filter based coloring was due to the fact of how much time it took to go through each system type and change its color to black before uploading, due to client requests. Sure it took time to set up all the filters, but the time saved not having to manually change colors to black before uploads was easily worth it. I suppose Dynamo could now help "automate" that task.
                  As for performance hits, I don't recall any difference after making the switch although I never ran a comparison.
                    Or the client could add a single pipe filter to his view(s) to change them all to black instead. Filters trump Piping Systems Properties graphics.
                    • Piping Systems
                      Currently we have 64 different Piping Systems. When it comes to filters, I have managed to group some of them by system classification. However, some...
                      August 13, 2014, 05:51 PM
                    • Filters
                      I am new user to revit MEPI am trying to create a project using different pipework, I want to have these coloured red for hot, blue for coldI have managed...
                      May 2, 2014, 01:23 PM
                    • Riser Diagrams
                      any good threads or thoughts on creating view templates for plumbing riser diagrams?
                      I am trying to set up view templates to place in my project...
                      July 12, 2017, 11:12 PM
                    • Problem with filters, any suggestions?
                      Hey guys,
                      I received this project a few weeks ago and since then I've been fixing system problems, family problems, problems problems and...
                      April 21, 2017, 06:33 PM
                    • Displaying/Filtering pipework on sheets
                      How do you guys separate different pipework on different plans?
                      I wanted to use filters and filter them by System Type but it System type...
                      January 23, 2015, 01:35 PM
