Hi all,
I have created a railing family which allows me to insert my vertical laid and horizontally laid brick slip panels along lines and curves with lots of success. Where the system falls down is if you try to carry out railing along more than one length of geometry such as line and curve etc. Unless the line is an exact division of the the length by he segment size the point of interface overlaps on itself.
Is there a railing family setting or a work flow anyone can suggest which allows me to select multiple lines and apply the railing to the whole length of multiple lines which divide perfectly with segments.
Thanks in advance.
Liam
Thanks in advance.
Liam
