This is probably a stretch... but we've been doing furniture planning in Revit. I have filters applied to color code which furniture is being moved vs. discarded. First, I'd like to make a PDF from Revit where each furniture family can be moved around in the PDF after-the-fact. Even better if I can toggle the color the furniture in the PDF, too.
PDF export where you can move families in the PDF
Originally posted by elton williams View PostCan i ask why you want to do this in pdf? Is it so you dont have to replot from revit?
IMO having two sets of data will cause headaches. Better off sticking to mark ups in pdf and making changes from the model.
Yes, they have a "Dynamic Tool Set Scaler" in Bluebeam that makes components which will automatically resize in different scaled viewports
How Can I Get My Markups to Adjust to the Scale of a Drawing? – Bluebeam Support
I'm looking for a way to automatically make individual markups for each family in the furniture category. It seems like it would be also possible to publish changed made in the PDF back to the model; Fuzor has already accomplished this in 3D.
Originally posted by cbaze View PostThis is probably a stretch... but we've been doing furniture planning in Revit. I have filters applied to color code which furniture is being moved vs. discarded. First, I'd like to make a PDF from Revit where each furniture family can be moved around in the PDF after-the-fact. Even better if I can toggle the color the furniture in the PDF, too.
Or as previously noted Fuzor
Print the building PDF without the furniture. Print the furniture a separate PDFs. Insert the pieces as "stamps" in the base PDF. The end user can scale, rotate or move the pieces.
I've got an Engineer's digital stamp in pdf that I need to get on my titleblock family. What's the easiest way to do this?September 30, 2011, 04:46 PM
All,
Recently I was told to Use 'CUTE PDF' in Revit in lieu of ADOBE PDF writer.
Have any of you familiar with this 'CUTE PDF'?...March 18, 2015, 09:28 PM -
How do you export plan views in pdf format for a clients review?October 23, 2012, 04:30 PM
I had a strange request today.
One of my users want to take their plan view into Photoshop to add some shading etc.
No problem i thought,...January 23, 2014, 06:06 AM -
I printed a couple camera views and when printing to a PDF (Bluebeam) there is some triangulation / faceting in several areas that does not appear if...January 19, 2015, 01:43 PM
