Stair by Component
    Stair by Component
    I've always used Stair by Sketch, but I really need to get up to speed on Component.
    One of the people I support sent me this image & I have to admit I don't know how to do it in Component.
    He says he can't make the stringers work like the image on the right
    Can anyone give me some hints?
    TIA
    Dave Plumb
    BWBR Architects; St Paul, MN
    Start with stair by component....then switch to sketch...
      Oops. I guess I hit Send before I finished that last sentence
      even after Converting to Sketch
      Dave Plumb
        Add a break in the border line where you want the stringers to flatten out.
          This doesn’t work on my end Mike, but if one can live with some hacking, it is possible to do with landing. Uncheck same as run and tread, and delete unnecessary supports. Some adjustments like landing relative height and stringer structural depth on landing are necessary. Also in plan view, the stair outline needs to be turned off in VG, otherwise the landing could be confused with the riser.
          Pita compering to the stair by sketch.
