Double tub electrical panel?
    Hi everyone. From a quick search around it doesn't seem possible, but I was wondering if anyone here has found a proper workaround for creating a double tub electrical panel schedule? Or perhaps Revit 2017 somehow addressed this issue but I'm unaware?
    What I do is I have made a panel that you can turn on 2 or 3 panel tubs so that you can have 1 panel to represent the double or triple tub. Then for scheduling if for instance you want to make a double tub 42ckt each what I will do is change my panel to the double tub and then make it be an 84ckt panel. On the panel schedules you can do one of 2 things you can make a panel schedule template for the double tub and have it say double tub at the top or you can use the same schedule as all the others and use the schedule header notes and note that it is a double tub this is the way I do it but I have seen it done both ways. Hopefully that helps!
