Hi all
How do you all annotate/tag your pipes to show routing drops?
I've created a tag with labels which let me add things like FLL THL and sets across at LL etc, but then I'm running into a problem when I try and tag the pipe on the floor above or below and it still has the information relevant to the floor above or below associated with it.
For example the two screen shots attached shows the pipe on level 1 setting across at low level. Then the second screen shot shows level 0 where the pipe needs to be FA TB. Tagging the pipe gives me the same set across information as the pipe is, in effect, the same piece of pipe I tagged on the floor above.
I've tried adding a break with a socket connection but that didn't work.
Short of having dumb annotation for all the drops I'm stuck.
Any help/tips would be appreciated.
Cheers
Jon.
Cheers
Jon.
