Attached are two screenshots of a problem I'm having.
I have a large number of stacked walls in this project. The core of the walls are consistent. It is where there is a finish material change that the cleanups aren't working as intended. I've adjusted the wall joins to be mitered as the two screenshots show. The finishes are all either 5/8" or 3/4" thick. All the exterior finishes have their function set as "Finish 1 [4]" in the wall types. All the substrates are "Substrate [2].
The failure to join correctly is not consistent. I have no idea what broke. So if somebody can help me understand what is wrong I'd appreciate. it.
