Ladies & Gentlemen,
The Goal
To have a set of face based families for use in reflected ceiling plans so that in the event a user accidentally deletes a ceiling they won’t also delete the elements hosted by it.
The Snags
Are these snags related to the limitations of basic ceilings or am I overlooking something? Thanks.
The Goal
The Snags
- When placing these families in a basic ceiling (as may happen during design) they won’t cut the ceiling.
- When changing a compound ceiling that is being cut by these families to a basic ceiling (which is a possibility I can’t rule out) I am forced to delete the family instances because Revit “Can’t cut instance(s) of it out of it’s host” and “Highlighted geometry no longer determines a plane.”
