I am trying to create ISO views of my piping system for spooling and am not finding anything that is helpful in creating the views. Any help would be greatly appreciated.
ISO views
Like the PDF attached? Or more single line look?
Either way, just create a 3D View, and adjust the V/G accordingly to get the desired look. Have you ever approached this before? If not we can assist you if you can tell us what your expectations are in how you want it to look once complete.
-TZAttached FilesTannar Z. Frampton ™
Frampton & Associates, Inc.
I am more trying to isolate a section of pipe. In the pdf it would be the section with the two pumps. I was able to get close to what I was looking for using the view section box. It still has to be isolated a little because it is showing some extra pipe that I don't know if it is possible to stop.
Originally posted by tzframpton View PostLike the PDF attached? Or more single line look?
-TZ
So which is it, and iso (which means isometric, therefore a three plane perspective, aka "orthographic 3D view") or a section? Sections are easy. Hiding and showing pipes as needed can be as simple has literally Hide Elements so as long as your Section extents encase all the piping you're needing.
-TZTannar Z. Frampton ™
I dunno, I'm confused lol. Glad you got it figured out.
Originally posted by evan.dodds View PostAlso, TZ do you have shadows turned on in your iso? They look pretty cool.
Hey there!
I haven't seen this issue yet, so I'm hoping someone else has run across it to know what is going on!
I'm doing MEP...March 25, 2019, 12:38 PM -
Howzit guys,
Can someone tell me how i can create section marks on only my "duplicated views", so that they don't pop up on all...-
August 14, 2014, 01:24 PM -
I am trying to figure this problem out. As you can see in the attached image, I have a 3D View categorized as a Section in one of our project files....March 22, 2011, 03:52 PM
Good morning all, i am working on site storm drain development that needs long profiles, AFAIK civil 3d can generate profile easily wich i dont have,...
Channel: MEP - General
May 2, 2014, 01:11 AM -
Hi Everyone,
I am trying to create some 3D views of water services & drainage pipe work, but when i apply the section box to the room...-
April 18, 2013, 10:06 AM -
