I have a linked dwg (site plan) that came in at true north. When I try to rotate to project north the crop region rotates with it. I haven't had this problem in other projects. Is there a way to rotate the crop region back to the original position?
Rotate Project North
I try to avoid rotating project north in Revit at all costs. If it were me, I would rotate the linked DWG file so that it matched project north in Revit, then rotate true north in Revit to match the survey. Project north in Revit is simply the top of your monitor, or in other words, it defines how your building will fit on your sheets assuming that your sheets are in landscape format.
I've got a project that has a rectangular property line which is more or less the same proportion as a D-size sheet, but is not aligned to either project...December 22, 2010, 07:25 PM
Ive read up on the subject and played about with my current project but theres still one or two things i'm a bit lost with and was hoping someone may...December 16, 2014, 09:12 AM
Say you have a building that is long and skinny along a N/S axis and you want the plans to fit on the sheet horizontally (i.e. rotated 90 degrees) Do...December 5, 2014, 08:27 PM
Hello all,
My building has the correct coordinates (x,y) and the correct orientation True North.
I am trying Rotate the Project...July 27, 2018, 08:38 AM -
Hi all,
FIRST OFF THE TITLE SHOULD READ ROTATE PROJECT NORTH...SORRY
I have had a strange result after entering a simple rectangular site...October 31, 2019, 05:18 AM
