I am using Revit 2017.
I am trying to connect a duct from a shoe to another existing duct which has a different offset but the bends are not drawing in.
The offset of the shoe is -250mm and the offset of the duct is -750mm.
I go into the “Systems” tab, and in the “HVAC” panel, I select the “Duct” button. I click onto the centre of the shoe face, and in the “Modify|Place Duct” contextual tab, I select the “Automatically connect” button. I then click onto the centre of the existing duct and the duct is drawn straight. A message comes up saying, “There was not enough room to place the required fittings. Consider increasing the length of the segments, or moving them farther apart to generate a solution.”, where there is plenty of space between the points, say, 1000mm distance horizontally.
Many thanks. Tim. :banghead:
