Is there any free Revit viewer for download?
Is there any free Revit viewer ?
yes take a look of this Download Design Review | DWF Viewer | Autodesk
A current version of Autodesk Design Review 2014 and 2015 does not exist - the most current version is still the 2013 version.
The DWF and DWFx file format has not changed in the last releases - due to this fact, the 2013 version of Design Review still offers full functionality of measure and markup.
Design Review 2013 can also open DWF and DWFx files that have been created from other 2014 and 2015 Autodesk products.Last edited by Andres Franco; March 8, 2017, 08:40 AM.Andres Franco - Architect - BIM Coordinator
E.A Poe
Originally posted by Andres Franco View Postyes take a look of this Download Design Review | DWF Viewer | Autodesk
But I would like to find out free perpetual Revit viewer. Anyway, thanks for your information.
Raymond Cheung
This is a list of ideas andpossibilities. Review to see which one best meets your needs.
· Use the free online A360 Viewer
· Download the free DesignReview 2013 and export the Revit model as a DWF.
· Use the Revit viewer mode. This isexplained in the article: Howto use Revit Viewer Mode
· If you have Navisworks, you can open theRevit file in Navisworks, then save as an NWD file. That NWD file canthen be viewed in the Free Navisworks Freedom viewer.
· If you are using A360Team, you can invite others to the project and they canpreview the 3D model there.
· If you export the Revit 3D view to an AutoCADDWG file (and likely best as ACIS solids), that file can be viewed in AutoCADor AutoCAD360
· Check for Revit Viewers at the Autodesk RevitApp Store
· Subscribeto Revit or try it free for 30 days
· Subscribe to Revit LT
· Try Revit LT free for 30days
for me the best options are:
regardsAndres Franco - Architect - BIM Coordinator
E.A Poe
Hey, I thought the free Revit viewer was basically the Revit trial; when it expires it can continue to be used as a free Revit viewer.
Of course it doesn't save any changes, otherwise you're looking for a free Revit EDITOR, which doesn't exist.
Kamran Mirza
When you install Revit, it creates a Revit XXXX on the desktop. If you look under your All Programs list (if Win 7) under Autodesk --> Revit 2017 for example you will have a link for Revit 2017 and Revit Viewer 2017.
Of course printing, saving and exporting is disabled with the installed Revit Viewer. But the nice thing is it doesn't require a license. Lots of people miss that it is installed because it isn't on their desktop.Michael "MP" Patrick (Deceased - R.I.P)
Just wondering... could you use Dynamo to extract (And change?) information with Revit Viewer?"One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
Maybe wat I say is not clear, wat I want is put out de color from selected object ?
Normally for change color I do did:
Dim MyElement...-
Channel: Third party Add-Ins, API and R&D
December 2, 2018, 12:56 PM -
Here are some exceptions of view range that should be known carefully, because some are confused when dealing with View Range levels....
1.January 16, 2016, 09:19 AM -
Install and Run Windows Powershell
Give yourself unrestricted script access:
Set-ExecutionPolicy Unrestricted
Make a list of...-
Channel: Blog Feeds
December 4, 2013, 01:45 AM -
Hello
If anyone would be kind enough to help me.
That's my problem,
I would like to insert a shared parameter associate with...-
June 4, 2018, 04:24 PM -
Make S Ride on The Rails: by JBZ takes the win by a nose!
And in second place
Column and Beam Issue. Is it possible?: by Munkholm...November 29, 2011, 07:02 PM
