Key Schedules and Filters
    I suspect the answer is No, but can I use the value of a Key Schedule (Key Name) in a Filter?
    I don't see it available.
    Dave Plumb
    BWBR Architects; St Paul, MN
    I'm seeing it in the Schedule Filters, but missing it from View Filters. However, I AM seeing the Project Parameters that are "keyed" to that Key Schedule. An additional redundant keyed parameter may work for you.
    Chris Ellersick
      I already had to write a Dynamo graph the sync the Key Schedule's parameters to the family Tag's Shared parameters, so I guess it won't be that difficult.
      I was just hoping it could be more automatic.
      Of course, if we could use Shared Parameters in Key Schedules, that would avoid the whole problem.
      https://forums.autodesk.com/t5/revit.../idi-p/6254607
      Dave Plumb
