Problem with Paint?
    Problem with Paint?
    Revit 2016 - I had a roof with two perspective views. Once I applied paint, one view showed it correctly and the other did not. See before snip of the same roof in two different views. The only way to make the material show the same in both views was to "cut" and "paste" the geometry to the same place. See after snip of the same roof in two different views.
    before
    after
    Yeah perspective (and iso?) views can rotate the patterns when orbiting, its a per view thing and is a bit disconcerting...
      I have both types of views in this project. I generally did not have problems with the iso views not updating. It was only the perspective views. Typically, I do not use perspective views so this is the first time I came across this issue.
