Sub category for revision clouds
    I was recently informed that you could add sub categories to revision clouds, I'm not sure if this a new thing since 2016 or if it's been around for awhile. The real question is, can they be used? Yes you can add them, but you can't assign the sub category to the revision clouds.
    Is this like the roads category? It's there, but can't be used?
