I am trying to model a body of water that is a pond or small man-made lake. I have regraded the topography now I need to fill the void. anyone have a suggestion?
modeling body of water (2017)
Why not just use a thick floor (or model in place box) set to the correct elevation? It can just overlap the topo as the water would only show where the elevation works out.Rob Pivovarnick, AIA
Senior Project Architect
Michael Graves Architecture and Design
LinkedIn Profile | @ Twitter
I use a thin Floor not thick, so it shows up as just the water line. Never needed to show anything filling the pond, just the height of the water.Scott D. Brown, AIA | Senior Project Manager | Beck Group
Lauren Schmidt over at landarchBIM has a good primer on doing it with Dynamo, if you need more than just an approximation as you get with a thin surface layer.
I am working on a project where I want to model a toposurface for grade (soil), then down lower I want to model the elevation of bedrock.
...August 18, 2017, 12:57 PM -
so we are well into our project/ model and we just found out that Civil has dropped our Main Level FF elevation 3 inches. I was wondering what the recommended...December 13, 2016, 04:41 PM
Hello Revit users,
After spending hours working on a site model with the site designer plug in, i realized that it does not do roundabouts...February 16, 2015, 11:46 AM -
Do you have something to say about site topography in Revit?
If so, then now is the time for your voice to be heard!
Lets hear from...April 26, 2013, 08:06 AM -
Hello all,
Have you all run into this issue? We always have a constant need to build a topo surface for the project site model in the office....August 23, 2012, 03:36 PM
