Good Morning/Afternoon/Evening however this finds you.
I am struggling a little and wondered if anyone could help me.
I am revising the dwg Export Layer/Colour system I set up a few years ago, and I am unable to give a structural column a different layer for a Cut hatch.
I have searched and found a few posts on other forums for a similar issue from around 2014 but nothing really updated.
I am using Revit 2016 (Not Revit Structure 2016) as they dropped the other sub-Revits (if you will) to form a single program in 2017 (I believe)
I have tried added a modifier to look for the Material for model behavior and this seems not to work as the element is still being exported as a block. I have gone into the family and ticked the box Always Export as Geometry, this does not seem to help or work.
I am sure there must be a fix for this, very basically I would like (and I don't think its too much to ask)
Structural Column Layers
1 - Outline x2 Cut and Projection
2 - Cut Hatch
In am sure I am missing something pretty basic here but to be honest its a Friday, and I am losing my patience with it.... IN NEED OF BEER and if possible a solution!
Thanks in advance
James
2 - Cut Hatch
Thanks in advance
James
