I hate setting things up for people in Revit that are such obvious manual hacks just because they're used to seeing it that way.
Hacks
Example?
Personally; my (current) beef is an (unhealthy) obsession with modelling everything (too early). Don't get me wrong, I'm a big BIG fan of modelling minutiae when (it is) appropriate, but tying a model up in knots with overtly complicated modelling practices without even first floating an idea in rough sketch form beforehand just feels wastefully decadent.
I like to ask people "Would you rather have it look the same and take longer, or would you rather have it work better that it did before?"
Sure, maybe you can have your Door Schedule have the same line spacing as it did 15 years ago by drawing lines and typing text.
Or you can have it generated automatically, be accurate, and require no effort whatsoever. Net even "additional" effort. NO effort.Dave Plumb
BWBR Architects; St Paul, MN
Originally posted by snowyweston View PostExample?.
I get the idea (convenience) but at what cost of relying on information you can't remotely ensure is accurate?Greg McDowell Jr
about.me/GMcDowellJr
Originally posted by GMcDowellJr View Postjust because they're used to seeing it that way.
Originally posted by GMcDowellJr View Postbut at what cost of relying on information you can't remotely ensure is accurate?Chris Ellersick
Originally posted by cellersick View Postsounds like it might be time to Dynamo-metize things and ensure that accuracy yourself!Greg McDowell Jr
Originally posted by GMcDowellJr View PostYes - I've just got to get them to the table for the discussion. Last time I showed something I was told it was "way too complicated.".....Change seems to equal bad for some.
So that's good, but I never would have guessed you'd need to know 3 separate programming languages* to accomplish it. But here we are.
Software can't fix stupid, but at least it can automate it.
*: C#/VB - Revit API
DesignScript / nodes - Dynamo
Python - Dynamo (not all of the API is exposed to DesignScript)Chris Ellersick
I think it's the direction of the change but as it relates to their skill set. I remember the days when hand drafters wouldn't learn AutoCAD and the days (now) when AutoCAD users didn't want to learn Revit. The change makes them obsolete (or so they fear).
Check out Emblemmatic — MarkMaker to see why designers ought to be worried.
3 languages, at least. Add in Flux and Grasshopper and you've got a few more!Greg McDowell Jr
Originally posted by GMcDowellJr View Postwhy designers ought to be worried.
It's looking like a waiting game until designers are replaced by algorithms. I'm waiting for the "Mid Century Modern" plugin pack, myself - I hear that one has the 'Mies' algorithm.Chris Ellersick
I'm always very impressed when I see engineering drawings done in the age of pencils and drawing boards and I would like to try and recreate the same...February 9, 2013, 08:17 PM
That being said, ask anyone if revit is well written software and they'll also give you a quick and firm "No" without hesitation. Keep working,...
Channel: Out There
December 20, 2013, 04:08 PM -
This is a repost from September 2009 based on having this conversation a couple times recently....
Every now and then I read an article pumping-
Channel: Blog Feeds
November 14, 2013, 08:15 PM -
I am very likely overthinking this. But I'd like to get some input from the knowledge base here..
The first image is how I typically tag...January 21, 2021, 10:12 PM
